Kona LHi residual audio static
David de Vos
on Aug 6, 2009 at 5:56:58 pm
Just set up Kona LHi with Mac Pro Harpertown 2.8 eight core running Final Cut 6.0.6. It worked fine for a few days, but now I'm getting a strange residual audio static every I stop the playhead, whether I'm editing, watching in the viewer, or playing back via the timeline. It's like it's echoing the last few seconds of audio, but with a very annoying static burst mixed in. It trickles off to silence, but happens again each time I move the playhead. Anybody comes across this? I checked my amp, but I'm getting the static signal into my mixer, which is directly out from the Kona.
Any thoughts?
Jeremy Garchow
Re: Kona LHi residual audio static
on Aug 6, 2009 at 7:59:49 pm
Are you running your system sounds through the Kona?
David de Vos
on Aug 6, 2009 at 8:49:29 pm
Yes.
Jeremy Garchow
on Aug 6, 2009 at 8:58:07 pm
Try turning that off and see what you get. If you need system sounds through your audio monitors, simply send a cable from your headphone/line out of your mac into your mixer.
Jeremy
Vince Sanchez
on Aug 6, 2009 at 9:09:46 pm
I get the same thing, and I don't have my system sounds sent to the Lhi. It was bad for a while but its only once in a while now.
Vince Sanchez
Intel Quad Mac 2.66
AJA LHe
HD link
OSX 10.4.11
FCP Studio 2
David de Vos
on Aug 6, 2009 at 9:17:40 pm
Thanks for the response. Under "System Preferences," I set all my "Sound Effects" to play through the internal speakers, and Audio Input and Output set through the Kona.
Still have the problem.
Jeremy Garchow
on Aug 6, 2009 at 9:29:10 pm
[David de Vos] " and Audio Input and Output set through the Kona. "
Don't set those to Kona. Set the output to Headphones or Line Out, and the input to internal mic.
Jeremy
David de Vos
on Aug 6, 2009 at 9:54:02 pm
Okay. Did that. Still no change. Darn gremlins...
Bob Zelin
on Aug 6, 2009 at 10:20:38 pm
AJA Control Panel
Control Tab
1) make sure you are not on "input passthru"
2) are you on FREE RUN, or EXT REF. You better not be on VIDEO IN.
3) if you are on EXT REF, what is your black gen ?
Bob Zelin
David de Vos
on Aug 6, 2009 at 10:39:18 pm
Output: Test Pattern
Genlock: Freerun
David de Vos
on Aug 7, 2009 at 12:58:43 am
Unfortunately, even with the right Kona card settings, I'm still having the problem.
Jeremy Garchow
on Aug 6, 2009 at 10:45:35 pm
And if that doesn't work, try an uninstall and reinstall of the drivers.
Jesse Coane
on Sep 22, 2009 at 1:14:24 pm
I've been having this issue on and off since we get our Kona LHI cards. Lately it's been very annoying. I've tried everything listed here. Did anyone have any luck on sorting this out?
thanks in advance
jesse
Jesse Coane
Director / Editor
The Concept Farm
David de Vos
on Sep 22, 2009 at 4:27:13 pm
Hi Jesse,
The only fix I found - and yes, it DID fix the problem even though it's a pain to do - is to reinstall OS 10.5.8 after you've physically installed the Kona Lhi. THEN download and install the latest NDD (make sure it's NDD, otherwise your monitors will be screwed up) driver.
It took me a while to do, but it worked. The static issue has not returned. Let me know if it works for you.
Best,
Dave
Jesse Coane
on Sep 22, 2009 at 6:02:11 pm
thanks man. did you do a clean install? would an archive and install be sufficient?
thanks again
jesse
Jesse Coane
Director / Editor
The Concept Farm
David de Vos
on Sep 22, 2009 at 6:13:57 pm
I had just upgraded to my Mac Pro, so I did a full clean install. You could try either, I suppose. If it works, great. If not, try the other way. Let me know if it works! Don't forget to repair disk permissions when you're done.
