Kona LHi - HDMI output stopped working
Krzysztof Kalukin
on Jun 24, 2009 at 11:12:18 am
Hello,
Yesterday I had to disconnect my HDMI monitor which was used for HD monitoring. When I reconnected it, I can only see "No signal" message. Monitor is OK, because it works with other sources. Kona outputs analog signal without any problems, but HDMI does not work. I tried to reset, change settings, etc - no effects. What can be wrong? What should I do?
Please help.
Krzysztof
