No immediate monitorredraw while colorcorrecting in FCP
sven giebel
on Jun 11, 2009 at 6:03:18 pm
maybe you can help me on this one:
when I'm using the 3way colorcorrection effect I usually activate the effect via a shortcut and start correcting in the effectwindow. I see the changes immediately in the canvaswindow but not on the big panasonicdisplay which is hooked up on our second LHe SDI-output. I have to click into the canvaswindow to force a redraw on the panasonicdisplay (where I have activated the build-in waveformdisplay). Not only is this pretty annoying over the day, it's also risky, as it already happened to me that I changed the clip position without immediately noticing it.
Is there a better way to do this? Are there any settings I've overlooked?
Sven
Matt Larson
Re: No immediate monitorredraw while colorcorrecting in FCP
on Jun 24, 2009 at 4:24:49 pm
Pull the Color correction tab out to a seperate window on your screen (so you can see the CC wheels and the Viewer window) Then you will get real-time feedback on your external monitor
2 x3Ghz Quad MacPro
9 GB RAM
Mac OS X 10.5.5
QT 7.5.5
FCP 6.0.5
AJA Kona 3 (6.0.1 drivers)
G-Speed XL 12 RAID
