HDMI preview
Krzysztof Kalukin
HDMI preview
on Jun 5, 2009 at 6:23:15 pm
Hello,
I've connected full HD LCD display to HDMI output of Kona 3 LHi. Test bars appear, but colors are not correct - white bar is cyan, blue is pink, black is red, etc. That monitor does not have HDMI input, but we used HDMI<>DVI adaptor. Any ideas what's behind that problem?
Thanks in advance
Krzysztof
Arnie Schlissel
Re: HDMI preview
on Jun 6, 2009 at 2:35:47 am
[Krzysztof Kalukin] "That monitor does not have HDMI input, but we used HDMI<>DVI adaptor. Any ideas what's behind that problem?"
Probably your HDMI to DVI adaptor. What kind of monitor is this? What other connectors does it have?
[Krzysztof Kalukin] "I've connected full HD LCD display to HDMI output of Kona 3 LHi."
Is it a Kona 3, or is it a Kona LHi? These are 2 different cards.
Arnie
Post production is not an afterthought!
http://www.arniepix.com/
Krzysztof Kalukin
Re: HDMI preview
on Jun 6, 2009 at 7:57:13 am
That's iiiyama Pro Lite e2208hds. I conntected that monitor do DVD player using the same HDMI cable - everything is OK. When I connected other LCD monitor to Kona - situation the same - colors are not correct.
The card is Kona LHi of course.
Krzysztof
Ramona Howard
Re: HDMI preview
on Jun 10, 2009 at 1:16:33 am
Don't forget to add that you can push ANY colorspace down HDMI and DVI you can not!
So start with the content, is it higher than 8 bit 4:2:2? If it is then, guess what, it won't look the same no matter what you do.
If it is only 8bit 4:2:2, then move onto the next issue to rule out.
Best of luck
Ramona
Play hard today, it may be raining tomorrow!
