G5 sees a kona2 as a PCI and not a PCI-X
Joseph Bradley
on Jun 1, 2009 at 12:32:23 am
I have a G5 2.0 dual with a Kona2 card. it is in slot 3. The card was recently repaired. i put it in and it did not work. When I went to the info tab it said that the card was operating in PCI mode and there should be a PCI-X card in that slot. I am running 10.5.5 so I used the 6.0.3 driver. I then uninstalled it and tried the 5.1 driver with no change. I trashed the prefs of the Kona and Quicktime but no luck. Any help would be appreciated.
Rob LaRose
Re: G5 sees a kona2 as a PCI and not a PCI-X
on Dec 14, 2011 at 6:33:06 pm
Hi Joseph,
I'm experiencing this same issue right now -- do you by chance remember what solution you landed on?
--Rob
Joseph Bradley
on Dec 14, 2011 at 9:30:02 pm
The number four slot was unavailable to me because of the screws on the chassi were bad. I ended up getting a new machine and an LHe card.
Rob LaRose
on Dec 14, 2011 at 9:42:33 pm
Bummer. :-)
Thanks for the response! :-)
--Rob
