Capturing from VHS using Kona
Jason Rodriguez
on May 26, 2009 at 7:49:14 pm
I have stuff on VHS on EP mode i believe, is it possible to capture from a vcr through a kona 3 through fcp..if so...what cables or what will i need? thanks
btw using mac osx version 10.5.6/ 2x3 ghz quad/6gb memory thx
walter biscardi
Re: Capturing from VHS using Kona
on May 26, 2009 at 8:51:04 pm
No analog inputs on a Kona 3. You'll need to use another input device.
Do you have a DV deck or something with composite or S-Video inputs?
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
Read my Blog!
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Craig Thomas Quinlan
on May 26, 2009 at 8:58:21 pm
K3 has no analog input. The Kona LH does. If you need to capture analog sources to a Kona 3, you need a A/D converter like the AJA HD10AVA, which will embed analog video and audio into an SDI output. VHS is tricky though, you should drop a TBC inbetween. Alternatively you can run it through an AJA FS1, which will give do the same thing (as one of its many purposes) but also gives you TBC and frame sync. Run your rca analog outs on the VHS deck through a mixer before you hop onto the converter.
on May 26, 2009 at 8:58:59 pm
(Or dub your VHS to dvcam or similar)
Bob Zelin
on May 26, 2009 at 9:58:44 pm
sorry Craig, but the converter won't work. SDI input products require a STABLE SYNC SIGNAL. IF you go into an AJA A/D converter, the VHS still won't lock up. If he had an AJA Kona LHe, it would not lock up, becuase there is no frame sync input (like there is on the old AJA I/O box).
The best suggestion was dubbing the signal to something like a DV deck, or even analog Beta, and then playing it back in a Digi Beta VTR. Or get a frame sync with an SDI output.
Sorry, no easy answer. And it's not even VHS SP - you are going to need a frame synchronizer no matter what.
Bob Zelin
on May 26, 2009 at 10:09:36 pm
Yeah, you're right. We usually dub VHS to dvcam here.
If you already have an FS1, you should be good to go though, right? TBC and frame sync?
Jason Rodriguez
on May 27, 2009 at 3:04:39 am
thanks for the replies. i am not sure about fs1 (or what it is). i have tried capturing it on an older system through media100 (ifinish) through an s-video cable and it was impossible, every couple seconds or frames it stopped.
we dont have a dubbing station. we have systems using digibeta and betasp decks going through kona.
Bob Zelin
on May 28, 2009 at 12:31:59 am
are you willing to spend money (buy equipment) to resolve this problem ?
Bob Zelin
Joe Murray
on May 29, 2009 at 1:50:19 am
Check out the Canopus ADVC110 - it's a firewire interface that will allow you to capture VHS into FCP, then you can switch back to the Kona for monitoring. They cost about $200, less than that if you're OK going with a used one. There's really not much point in spending a more than that to convert VHS to SDI, at least from a quality standpoint. I do not think this will work with copy-protected tapes, though...if you need that you'll at least need to go a different route. Like maybe dub to BetaSP via a frame synchronizer like the FS1, buy an AJA LA which would give you component as well as composite analog inputs, or follow one of the other suggestions in this thread.
Joe Murray
Edit at Joe's
Charlotte, NC
