Kona 3 crashing FCP
Kevin Crane
Kona 3 crashing FCP
on May 7, 2009 at 2:43:44 pm
Searched the forum and don't see anyone else with this particular problem:
FCP 6, Kona 3 (6.0.3), XD CAM footage & JPEG images. When we click on an image in the bin with our HD monitor on (analog component), FCP crashes with an error citing "AJA Video Output plugin" as the culprit. Turn the monitor off and we can work with no problem. We've trashed FCP prefs, repaired permissions, etc., which has narrowed the problem to the Kona. We're running three other nearly identical suites, this is only happening in the newest one.
We're about to trash Kona prefs; any other thoughts on what might be causing this?
Kevin
walter biscardi
Re: Kona 3 crashing FCP
on May 7, 2009 at 3:45:33 pm
If you updated your driver recently, try running the AJA Uninstaller, then run the 6.0.3 Driver installers again.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
Read my Blog!
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
gary adcock
on May 7, 2009 at 7:20:12 pm
[walter biscardi] "If you updated your driver recently, try running the AJA Uninstaller, then run the 6.0.3 Driver installers again."
And do not forget to update the firmware!!!
you will find it in the AJA Utilities folder.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Check out
http://www.aja.com/kiprotour/
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
