Kona LHe latency
Erik Mickelson
Kona LHe latency
on May 6, 2009 at 12:53:28 am
Anyone use the LHe with Amplitube?
I am going into my Mackie mixer with my electric guitar then from the Mackie outs into the LHe analog ins. From the LHe analog ins, then into Amplitube, then AES out of the LHe into my JBL studio monitors.
I am getting huge latency, the buffers in Amplitube "click" at 64 and 128 and there is huge latency even at those low buffer sizes.
MacPro Dual Core 2 Duo 3.0Ghz, 6GB ram, 1TB Raid, Tiger 10.4.11, FCPStudio 2
Erik Mickelson
Re: Kona LHe latency
on May 6, 2009 at 1:51:13 am
I just tried a decent condenser mic into the Mackie mixer/ analog in to LHe/ Soundtrack Pro = huge latency. The latency slider does nothing of note in the STPro preferences.
How are people hooking the LHe up for VO work in STPro?
Kent Stipp
on May 6, 2009 at 2:17:02 pm
curious to the reason if you are going in to the Lhe analog why are you not going out analog? have you tried that instead of using the AES out?
Kent Stipp
Life Begins at 155mph
Ki PRO Lens to Post
3am Studios llc.
3amstudios.org
Sharedsummitsfever.com
Erik Mickelson
on May 6, 2009 at 3:16:31 pm
Thanks for the help. Yes I have tried both analog and digital out. Both have the same latency.
I will be researching, firmware and software install/re-install now.
Erik Mickelson
on May 6, 2009 at 4:14:41 pm
Did a full AJA software uninstall and reinstall. Latency is low again!
Thanks Cow!
MacPro Dual Core2Duo 3.0Ghz, 6GB ram, 4TB SATA Raid, Tiger 10.4.11, FCPStudio 2, QT 7.5.5
