downconvert 720p to SD letterbox.. problem
jason levy
on Apr 27, 2009 at 12:55:01 am
Hmm. First time trying this. Trying to output a 720p timeline to the Digibeta doing a downconvert to SD letterboxed in the Kona LH (from FCP).
All the software is freshly updated.
Everything looks good (had to adjust the timing to get the letterbox to sit in the middle of the screen) but whenever there is fast movement in a shot everything moving goes big lines (on the sd monitor) as if the field order is wrong or something. It's pretty ugly.
Anyone know what I am doing wrong?
jason
walter biscardi
Re: downconvert 720p to SD letterbox.. problem
on Apr 27, 2009 at 10:24:00 am
Ensure FCP is still set up for 720p HD.
Ensure the Kona Control Panel is set up for the 720p as the Primary Format and SD as the Secondary Format.
Ensure the output you're using is set to the Secondary format.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
Read my Blog!
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
jason levy
on Apr 27, 2009 at 2:54:31 pm
Thanks Walter. I do have FCP set to the usual 720p.
I can't remember if I was using NTSC as the primary or secondary. I'll check later on. Do you know why that makes a a difference?
On another note, I couldn't make it work without feeding NTSC sync to the AJA card. If feeding HD sync then the DIGIBETA reports not getting sync.
Doug Beal
on Apr 27, 2009 at 2:46:12 pm
Also check your ref to the Kona and the dBeta. if the Kona is on free run set the dbeta to input video (out ref). You should not have to set the timing
Doug Beal
Editor / Engineer
Rock Creative Images
Nashville TN
