Cross Post: 444 in FCP is purple
Aaron Neitz
on Apr 9, 2009 at 1:01:58 am
Trying to digitize 444 RBG from HDCAM-SR. Final Cut is coming up with a picture - but it's washed purple.
I've confirmed the 444 coming out of the deck is correct: plugged it into a dual-link 444 compatible monitor.
I've got Dual Link selected in AJA control panel. Final Cut is looking for 10-bit RGB. I remember back in the day there was a specific 444 option in the capture settings, but it doesn't seem to exist in the 6.0.3 drivers.
FCP 6.0.5
Any tips?
Thanks!!!!
Ruslan Akmanov
Re: Cross Post: 444 in FCP is purple
on Apr 9, 2009 at 9:21:56 am
Hi Aaron
Where do You see purple picture? On FCP Capture screen or on Connected to AJA control monitor?
best regards
ruslan_3d
Aaron Neitz
on Apr 9, 2009 at 5:16:10 pm
Thanks, I solved the problem. I had a custom LUT apparently loaded in the Kona control panel... duh
