capturing audio from a NAGRA
howard wexler
on Apr 9, 2009 at 12:54:56 am
I want to capture audio from a Nagra, with no video, thru my Kona LH into FCP....Any advice?
hw
Bob Zelin
Re: capturing audio from a NAGRA
on Apr 9, 2009 at 10:24:58 pm
genlock with Pilot tone
(oh, I crack myself up).
Do you mean that you are using the antique reel to reel Nagra. Why use FCP and AJA at all - there are wonderful Steenbecks and KEMS out there - thats what the REAL FILM EDITORS work with.
I guess Grandpa never heard of Zaxcom.
The answer to your question is that you take the ANALOG AUDIO OUTPUT of your Nagra (is it on a bananna plug ?), and go into the ANALOG XLR INPUT of the AJA Kona LHe. You will need a bananna plug to XLR cable (I guess you are making that up, because no one sells these !).
On your FCP system, in Audio/Video settings, go to NON CONTROLLABLE DEVICE, because even if you have a Nagra IV, Final Cut Pro does not acknowlege linear time code. You could get a Horita box to force your linear time code signal into the RS422 port, but you will probably forget time code (I bet you have a Nagra III) and just send in your audio "free run". Will it lock up ? What the hell do I know - the Nagra is pretty damn stable, and it should lock up with your picture.
Even if you have a Nagra T, you will still face the same sync issues.
By the way, Stefan Kudelski says "thanks for still thinking about me".
Bob Zelin
Warren Eig
on Apr 10, 2009 at 7:26:11 am
Do you have to go through a resolver first to account for tape stretch etc., in order to maintain crystal sync? with 24 fps film, I assume you did use crystal sync and shot double system to film.
Warren
Warren Eig
O 310-470-0905
email: warren@babyboompictures.com
website: http://www.babyboompictures.com
http://www.babyboompictures.com/BabyBoomPictures/AFX.html
http://www.babyboompictures.com/BabyBoomPictures/KnitWits_Movie.html
http://www.imdb.com/name/nm0251670/
EDITING REEL: http://www.babyboompictures.com/BabyBoomPictures/Editing_Reel.html
TITLE DESIGN: http://www.babyboompictures.com/BabyBoomPictures/Titles_Reel.html
jason levy
on Apr 23, 2009 at 4:29:26 pm
Wow, havn't heard the term "pilot tone" in a long time. I feel a bit .. ill. Where did my youth go?
