AJA plugins for Adobe on Mac...
John Bollenbacher
on Mar 24, 2009 at 3:53:58 pm
Has anyone had success with the plugins?
I haven't been able to get them to work correctly for me since I purchased the card.
All the adobe presets put red render bars over footage, and the AJA presets have been buggy at best.
Anyone know of any preferences that need to be trashed? or best practices when installing?
John Bollenbacher
10engines
Paul Provost
Re: AJA plugins for Adobe on Mac...
on Mar 25, 2009 at 2:33:23 pm
are you in cs3? they haven't released cs4 drivers yet...
"HE'S SUCH A GIRL" HD feature film
grade and finish @ post + beam
http://www.hessuchagirl.com
http://www.postandbeam.tv
John Bollenbacher
on Mar 25, 2009 at 2:34:17 pm
Yes, I'm using CS3.
John Bollenbacher
10engines
Evan Thomas Phillips
on Mar 27, 2009 at 4:36:27 pm
I'm running CS3, and after I installed the Adobe Plug-ins, I couldn't get AfterEffects to play back rendered RAM previews in real time. I had to uninstall the Adobe Plug-ins to get AE working again. You should be able to look at RAM previews over your AJA output without the plug-ins anyway.
Kevin Christopher
on Mar 30, 2009 at 3:46:42 pm
You can. If you go into the AJA Preview setup there is a check box to turn off the preview. Just un check it and you will be back to just the AE Ram player. To make your preview performance better make sure auto scale is unchecked and your composition settings and playback settings are the same. Depending on your system that should get you closer.
Kevin
