kona-LHe -- pass through is pink when not in use.
Chris Borjis
on Mar 23, 2009 at 9:18:15 pm
I see pink on my monitor and not black when pass through is turned on
and no video signal is being played.
a bit annoying. anyone know how to make it show black?
it would be nice to not have to patch my deck in every time I want
to do a quick tape review straight to the monitor.
I do have input ref to house synch.
I'm running kona drivers 5.1
kona support told me that was the last version of the
driver I can use so everything works properly on my G5
and it holds true as I had tried every driver up to 6.03
Jeremy Garchow
Re: kona-LHe -- pass through is pink when not in use.
on Mar 23, 2009 at 9:45:43 pm
[Chris Borjis] "a bit annoying. anyone know how to make it show black? "
Turn it to black instead of passthorough? You can save presets in the Kona CP to quickly switch back and forth.
Jeremy
Chris Borjis
on Mar 25, 2009 at 5:00:32 pm
[Jeremy Garchow] "Turn it to black instead of passthorough? You can save presets in the Kona CP to quickly switch back and forth."
yeah I do that now.
I just wish it would do that with pass through. There really is not any reason
why it should be showing me pink (no feedback going on)
