Output is NOISE
Alan Smith
Output is NOISE
on Mar 23, 2009 at 8:02:39 pm
Running Mac Pro with Kona 3 (4.0) and Final Cut 6.0.5. Shot footage with XDCAM and imported via firewire (1440x1080 XDCAM HD). When I put it in my timeline, the image that is played out my Kona to my display looks lie blue snow. No useable image.
Kona set to HD 1080i29.97
Any ideas?
Alan Smith
Alan Smith
Media317
Check out my blog - http://media317.com
gary adcock
Re: Output is NOISE
on Mar 23, 2009 at 8:21:39 pm
[Alan Smith] "Running Mac Pro with Kona 3 (4.0) and Final Cut 6.0.5. Shot footage with XDCAM and imported via firewire (1440x1080 XDCAM HD)."
there are no video outputs enabled when you set to capture via FW.
you need to re-set your settings to output to via the kona at your frame rate.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Alan Smith
Re: Output is NOISE
on Mar 23, 2009 at 8:41:57 pm
[gary adcock] "there are no video outputs enabled when you set to capture via FW."
The issue is when playing from my timeline. When I add clips to my timeline and play the timeline, my preview monitors are nothing but blue snow noise.
Alan
Alan Smith
Media317
Jeremy Garchow
Re: Output is NOISE
on Mar 23, 2009 at 10:44:28 pm
What easy setup are you using?
gary adcock
Re: Output is NOISE
on Mar 24, 2009 at 1:21:50 pm
[Alan Smith] "The issue is when playing from my timeline. When I add clips to my timeline and play the timeline, my preview monitors are nothing but blue snow noise."
Like I said.
when you capture over FW -there is no video out-
Did you bother to change the seq settings or easy set up to allow for the video to play outvia the card or were you lazy and just assumed that it does not work?
if you capture over FW you have to change the Video out settings to achieve playback via the kona card.
gary adcock
Studio37
jerad sloan
Re: Output is NOISE
on Dec 10, 2009 at 3:52:26 pm
i'm having this same problem...did you ever find a solution for this?
