Nikon D90 & Kona
Nigel Thompson
Nikon D90 & Kona
on Mar 9, 2009 at 1:38:35 am
dudes:
tell me what you can, if anyone can about a kona editing footage from a nikon D90. AVI footage. does it handle exactly like QT stuff? should i transcode to QT?
Has anyone done this b4?
Nigel
HVX200, RED ONE, FCS and more,
High End, Production & Post Production
in the Caribbean
http://www.bistt.com
Nigel Thompson
Re: Nikon D90 & Kona
on Mar 9, 2009 at 2:22:01 am
thanks bob
in the Caribbean
Nigel Thompson
on Mar 9, 2009 at 3:11:36 am
ok thats cool:
but, if Kona & Xena are the same, then is there a possibility that the boards will handle the avi files like nobody's bizness. cuz i think that article was for ppl using FCP as a stand alone piece of editing software. Correct me if im wrong.
Will the boards drive the footage?
in the Caribbean
Michael Sacci
on Mar 9, 2009 at 4:12:13 am
The boards do not drive the footage. (they help with HDV and DVCProHD codecs). But they are capture/record and external monitoring cards. So the codec needs to be want FCP wants, which is QT. NOTE: QT and AVI are just the wrappers around a codec. Apple software wants things in a QT wrapper.
This really should be simpler than even what that article states. First if you have FCP or Express you have QT Pro so need to buy that. You also have Compressor with FCP (don't know about Express) so all you need to do is to convert the clips to 1280x720 ProRes and you will be golden. You can probably just convert the footage to a QT MJepg, just keep it the same frame size.
Nigel Thompson
on Mar 9, 2009 at 9:23:25 am
Hey Mike:
thanks for the advice, now i feel like and ass. bcuz i know all this already. cool i'll just uses prores which shud work fine.
in the Caribbean
Jeremy Garchow
on Mar 9, 2009 at 3:11:30 pm
[Bob Zelin] "http://michaelmistretta.com/2008/editing-d90-footage-in-final-cut/"
Wow, Apple Intermediate Codec?
Proverbially gag me with the proverbial spoon.
Nigel Thompson
on Mar 9, 2009 at 3:17:41 pm
you got that right, Prores it is.
in the Caribbean
Michael Sacci
on Mar 9, 2009 at 10:28:40 pm
I would bet the guy is a photographer and not an editor, several things in there are were ??????????????????????
