DVCProHD 720p 23.98 to 1080sf output - General Error (92)
Andrea Klipp
on Feb 17, 2009 at 12:38:38 am
Hi there~
For starters, not sure if this is a Final Cut Error or a Kona error. I am outputting a DVCProHD 720p 23.98 timeline to 1080 psf (23.98). Working in Final Cut 6.0.4, Kona 3, AJA control panel 6.0.2. Mastering to Sony HDWS280.
When I go to "Edit to tape" it starts the process - but then before it shuttles the deck it fails with the error: General Error (92).
The in point for the assemble edit is : 00.58.40.00. And the duration of content is 14 mins. approx. The Deck is set up at 23.98psf.
On the Kona Control panel - it show playback at DVCPro HD 23.98, and a 720-1080 convert to 1080sf23.98.
Not sure what is causing this error. Any thoughts?
Thanks, Andrea
Jeremy Garchow
Re: DVCProHD 720p 23.98 to 1080sf output - General Error (92)
on Feb 17, 2009 at 9:42:06 pm
What is your device control set to? It should be Sony 23.98 instead of Panasonic 59.94?
Jeremy
Andrea Klipp
on Feb 17, 2009 at 9:48:27 pm
Thanks for responding to the post. It turned out that it was my device setting - It was on the Panasonic 720p 59.94 - and after switching it to Sony 23.98 - poof the error went away.
Cheers,
Andrea
