Live Upconvert of 1440 to 1920?
Osiri Sioux
on Feb 10, 2009 at 2:14:53 am
Hi, all!
So, we're trying to view some footage captured as HDV-to-ProRes 422 23.98p using the SDI out on a Kona LHe to a Sony Luma monitor.
The Kona no likey. It'll give me still frames just fine, but if I try to play it, I get garbage video... Just a bunch of noise.
1920x1080 plays just fine, and I realize the obvious option would be just to media manage the whole project up to square pixels... And I also realize the irony in viewing a prosumer format through HD-SDI on a professional monitor.
But let's say that you didn't have the option to convert all your dailies to 1920, and since the footage is shot, the issue of what format it originated in is beyond your control...
Is there any way to watch 1440x1080 footage in realtime out through HD-SDI on the Kona?
Nick
walter biscardi
Re: Live Upconvert of 1440 to 1920?
on Feb 10, 2009 at 2:20:36 am
[Osiri Sioux] "Is there any way to watch 1440x1080 footage in realtime out through HD-SDI on the Kona? "
Yep, it does this natively when you play back DVCPro HD 1080i/50 material and HDV native 1080i material. Both are 1440 native anamorphic frame sizes.
Is your HDV material truly 23.98? If it's showing garbage, then your HDV material is probably playing back at 29.97 so you need to record to ProRes 1080i/29.97 (in NTSC.)
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
Read my Blog!
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Osiri Sioux
on Feb 10, 2009 at 4:17:32 am
Thanks so much for your response!
The video is true 23.98... Looking at the information in the format tab, here's what it is:
Vid Rate: 23.98 fps
Frame Size: 1440 x 1080
Compressor: Apple ProRes 422
Pixel Aspect: HD (1440x1080)
Field Dominance: None
Audio: 1 Stereo
Aud Rate: 48.0 KHz
Aud Format: 16-bit Integer
I believe those are the only items that would have an effect on the Kona's ability to play it. Anything here that might indicate why it's not liking it, or any other helpful information about the footage I could provide, just let me know.
Nick
gary adcock
on Feb 10, 2009 at 2:17:09 pm
[Osiri Sioux] "So, we're trying to view some footage captured as HDV-to-ProRes 422 23.98p using the SDI out on a Kona LHe to a Sony Luma monitor."
You need to use the AJA Kona 23.98 PsF settings- NO HDV camera can not output True P in 1080
this is a data format and not a video format. Your video will ALWAYS be 1920 x 1080 when playing out via the Kona Card. THERE is NO SMPTE output for 1440x1080- it does not exist.
"1920x1080 plays just fine, and I realize the obvious option would be just to media manage the whole project up to square pixels... And I also realize the irony in viewing a prosumer format through HD-SDI on a professional monitor."
OH so it got messed up by not handling all of the files in the same manner and now you have some that at ProRes at full raster and some that ProRes at the original "thin raster" of 1440.
you can reset all of the scaling issues and then re-save the files to solve this.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
