how long did you guys break in your plasmas?
Joel Arvidsson
on Jan 28, 2009 at 12:20:02 pm
how long did you guys break in your plasmas? 0h 100h or 200?
joelarvidsson@gmail.com
walter biscardi
Re: how long did you guys break in your plasmas?
on Jan 28, 2009 at 1:09:58 pm
Um, turned it on.
LCD's need to warm up for 30 minutes to come to correct temp each day.
I haven't noticed the plasma needing a warm up or break in period. We use the Panny Pro Plasmas and they're ready to go out of the box.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
Read my Blog!
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Joel Arvidsson
on Jan 28, 2009 at 3:29:20 pm
I mean like on http://www.eaprogramming.com/ and then click on the image plasma break in dvd.
"Just got that new plasma TV? Did you know that Plasma TV manufacturers suggest a 100-200 hour break in period? The first 100-200 hours is the time that your Plasma TV is most susceptible to burn in (learn more about burn-in Here at AVS Forums!). "
walter biscardi
on Jan 28, 2009 at 3:48:50 pm
[Joel Arvidsson] "I mean like on http://www.eaprogramming.com/ and then click on the image plasma break in dvd.
Never heard of this website, never heard of anything called a plasma break in dvd. No clue, we have 4 plasmas here, never needed a "break in dvd."
Read my Blog!
Jeremy Garchow
on Jan 28, 2009 at 4:24:08 pm
I think that break in period is really the period before you can calibrate it. Use it for about two weeks all day every day and then calibrate it. You should be fine. If you aren't editing that much, then wait three or four weeks.
Jeremy
Joel Arvidsson
on Jan 29, 2009 at 8:07:48 am
Do you guys have any good links how to calibrate panasonic pro plasmas (After i have used it for 2 weeks or more)? And I also wonder wich settings you use for screensaver and wobling?
Thanks for all support!
Joel Arvidsson
on Jan 30, 2009 at 8:38:51 am
Anybody?
walter biscardi
on Jan 30, 2009 at 11:32:55 am
[Joel Arvidsson] "Do you guys have any good links how to calibrate panasonic pro plasmas (After i have used it for 2 weeks or more)? And I also wonder wich settings you use for screensaver and wobling? "
I calibrate it by eye against our broadcast Sony CRT monitor.
No screensaver.
I have the wobble on, though sometimes it can be disconcerting and we'll turn it off when making a long playback.
Read my Blog!
Joel Arvidsson
on Feb 3, 2009 at 9:23:49 pm
I like it alot!
