Switching input on KL box within FCP
Jeff Jaynes
on Jan 7, 2009 at 7:50:21 pm
Hello,
We're trying to set up our new FCP 6 system and are having a bit of a problem switching from SDI to composite within FCP. Right now, to switch, we have to use the Kona control panel to make the switch. How do you switch the inputs within Final Cut Pro 6 from SDI to composite?
With thanks
Jeff
MacPro Quad Core
Kona Driver 6.0.2
FCP 6
Bob Zelin
Re: Switching input on KL box within FCP
on Jan 8, 2009 at 4:42:06 am
the Kona LH, LHe, and Kona 3 rely on the AJA Control Panel to select the inputs. You don't do this from FCP. This is not like on the regular AJA I/O box, where you choose Pro I/O SDI, or Pro I/O Composite from "Easy Setups" or Audio/Video Settings. You put your AJA Control Panel in the Dock, and call it up when you need to switch.
Bob Zelin
Jeff Jaynes
on Jan 8, 2009 at 11:41:47 am
Thanks Bob
