word clock?
Sean Davison
word clock?
on Nov 5, 2008 at 2:32:43 pm
I need to connect the AES outputs on my Kona 3 into an Audio suite but noe of the audio kit wants to word sync to the aes outpus - I just get a loud hissing noise. Is there a way of getting the Kona to clock to another source or of extracting a word signal?
Bob Zelin
Re: word clock?
on Nov 5, 2008 at 9:41:13 pm
I assume you are willing to spend some money.
The Lucid GENX192 will take an AES input, and create a sync'ed word clock signal for your system.
The Digidesign Sync IO will lock to house black, and output a Word Clock signal for your audio system. If you don't have a black gen, the composite video out of the Kona 3(the Y output) can go into the
video Ref input of the sync IO, and will generate a word clock signal for your audio system.
The Apogee Big Ben will also do this. Please state what your DAW is.
Bob Zelin
Sean Davison
Re: word clock?
on Nov 10, 2008 at 5:48:06 pm
Thanks Bob - I solved it with and old AES to Tdi converter and a Motu 2408. I now have a Logic 5.1 Setup
I need to sort out Dolby E now.......
http://www.twotallmen.co.uk
