Kona Lhe- Edit to Tape to DSR1500AP via SDI problem
Eugene Constable
on Oct 31, 2008 at 3:18:34 pm
Am trying to do an insert edit from Final Cut to a pre-striped DVCAM tape (using DSR1500AP)
I want to go out of my kona LHe card into the deck via SDI
When I perform Insert Edit, final cut starts the process fine, but soon my DSR deck says:
"Input video signal does not synchronize with reference video signal.
Use common ref signal."
It then stops recording.
I simply have the SDI Ins/Outs from the Kona LHe cabled to the respective INsOUTs on the deck...
A colleague tells me that SDI carries its own sync signal so no need to get a blackburst generator, is this true? If so how do I lay stuf off to my DSR using edit to tape and avoid this "not synchronize" message?
Eugene
Jeremy Garchow
Re: Kona Lhe- Edit to Tape to DSR1500AP via SDI problem
on Oct 31, 2008 at 5:53:43 pm
[Eugene Constable] "A colleague tells me that SDI carries its own sync signal so no need to get a blackburst generator, is this true?"
Yes and no. Your deck has to be able to select the incoming video signal as sync. If not, you need a blackburst generator and you will ser your deck and KOna to external reference.
Jeremy
Bob Zelin
on Nov 1, 2008 at 4:42:27 pm
where is my gun !
you write -
REPLY - you know the answer - you stated it in your post - the answer is on the screen right in front of you. Stop listening to you colleague.
Bob Zelin
