Kona LSe unable to recognize PAL Digibeta using version 6.1
Dustin Lau
on Oct 31, 2008 at 3:47:16 am
I recently had a Sony DVW-500P connected to a Kona LSe card. I was originally running on the 5.1 NDD driver version when this deck was installed. I experienced problems getting embedded SDI audio in and out of the deck to the MacPro. Thus, I installed the latest version of the driver (6.1).
Upon installing this driver, embedded SDI audio now functions but I am unable to ingest from the deck. FCP only recognizes the input signal from the deck when the capture setting is set to an NTSC preset, but the deck and tapes are all PAL. I can also see that while the video input signal is stable, I am losing the 96 lower lines of resolution and do not get any audio signals on the input. I did not have problems getting a stable video signal on the PAL presets when I was using the 5.1 NDD driver. Unfortunately, I need SDI embedded audio, otherwise, I would have downgraded to it immediately.
I am running the Kona LSe card on this machine.
Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 2 GB
Bus Speed: 1.6 GHz
Boot ROM Version: MP31.006C.B05
SMC Version: 1.25f4
My Kona Control Panel diagnostics are pasted below.
Hardware ID: KONA LS (0x10183400) S/N 00G83041 XLR Breakout Cable
VideoProc Bit file: 2008/08/18 14:28:00 (SD)
/Library/QuickTime:
6.0.1 - AJACodec.component
6.0.1 - AJADigitizer.component
6.0.1 - AJAMuxer.component
6.0.1 - AJAUncompressedCodec.component
6.0.1 - AJAVideoOutput.component
6.0.1 - AJAVideoOutputClock.component
6.0.1 - AJAVideoOutputCodec.component
1.5 - FCP Uncompressed 422.component
1.4 - DVCPROHDCodec.component
1.2 - AppleIntermediateCodec.component
1.4 - AppleHDVCodec.component
1.0.2 - AppleProRes422.component
/Applications:
6.0.1 - AJA ControlPanel.app
/Applications/AJA Utilities:
6.0.1 - AJA Conflict Checker.app
6.0.1 - AJA Data Rate Calculator.app
6.0.1 - AJA DPXToQTTranslator.app
6.0.1 - AJA QTToDPXTranslator.app
6.0.1 - AJA System Test.app
6.0.1 - AJA TV.app
6.0.1 - AJA Uninstaller.app
/System/Library/Extensions:
6.0.1 - AJAKONALS.kext
/Library/LaunchDaemons:
07/26/2008 07:45 - com.aja.ajadaemon.plist
/usr/libexec/:
09/23/2008 01:55 - ajad
/Library/Application Support/Final Cut Pro System Support/Plugins:
09/23/2008 01:59 - AJA Kona RT Enabler
/Library/Application Support/Final Cut Pro System Support/Custom Settings/Kona LS Easy Setups:
05/16/2007 01:53 - AJA KONA LS- NTSC 10 Bit Uncompressed.fcpre
05/16/2007 01:53 - AJA KONA LS- NTSC 23.98 10 Bit Uncompressed.fcpre
05/16/2007 01:53 - AJA KONA LS- NTSC 23.98 8 Bit Uncompressed.fcpre
11/29/2007 03:12 - AJA KONA LS- NTSC 23.98 Apple ProRes 422 (HQ).fcpre
11/29/2007 03:12 - AJA KONA LS- NTSC 23.98 Apple ProRes 422.fcpre
05/16/2007 01:53 - AJA KONA LS- NTSC 8 Bit to DV.fcpre
05/16/2007 01:53 - AJA KONA LS- NTSC 8 Bit to DVCPro50.fcpre
05/16/2007 01:53 - AJA KONA LS- NTSC 8 Bit to IMX-50Mb.fcpre
05/16/2007 01:53 - AJA KONA LS- NTSC 8 Bit to P-JPEG.fcpre
05/16/2007 01:53 - AJA KONA LS- NTSC 8 Bit Uncompressed.fcpre
11/29/2007 03:12 - AJA KONA LS- NTSC Apple ProRes 422 (HQ).fcpre
11/29/2007 03:12 - AJA KONA LS- NTSC Apple ProRes 422.fcpre
05/16/2007 01:53 - AJA KONA LS- PAL 10 Bit Uncompressed.fcpre
05/16/2007 01:53 - AJA KONA LS- PAL 8 Bit to DV.fcpre
05/16/2007 01:53 - AJA KONA LS- PAL 8 Bit to DVCPro.fcpre
05/16/2007 01:53 - AJA KONA LS- PAL 8 Bit to DVCPro50.fcpre
05/16/2007 01:53 - AJA KONA LS- PAL 8 Bit to IMX-50Mb.fcpre
05/16/2007 01:53 - AJA KONA LS- PAL 8 Bit to P-JPEG.fcpre
05/16/2007 01:53 - AJA KONA LS- PAL 8 Bit Uncompressed.fcpre
11/29/2007 03:12 - AJA KONA LS- PAL Apple ProRes 422 (HQ).fcpre
11/29/2007 03:12 - AJA KONA LS- PAL Apple ProRes 422.fcpre
Possible conflicting QuickTime components:
No conflicting files found.
http://www.luminoir.com
