Removing Playback Output options
Matt Gerard
on Oct 17, 2008 at 2:36:45 pm
Is there any way to decrease the number of options in the FCP Video Playback drop list in the Audio/Video settings box? I hate having to scroll through 35 settings when I actually only use 2 or 3. I've talked to AJA support, they seem to know less about it than I do.
MAtt
Its more fun to ride a slow motorcycle fast than a fast motorcycle slow...
Jeremy Garchow
Re: Removing Playback Output options
on Oct 17, 2008 at 5:59:17 pm
What Kona do you have and what version of the software?
Jeremy
Matt Gerard
on Oct 17, 2008 at 6:14:24 pm
Kona LH, Control Panel version 5.1
Just looked, and see there's a 6.0 update. I'm downloading that now. Will that help me out any?
Matt
Jeremy Garchow
on Oct 17, 2008 at 6:27:16 pm
In the setup tab of the Kona Control panel of the new software, you can select which presets load. I think this feature is available for the LH, I'm not sure.
Basically it will narrow it down to NTSC based frame rates (29.97/59.94/23.98)
or film based (24.0/60.0/30.0)
or PAL (25/50)
Select what you need and deselect the others, then launch FCP.
It cuts down on the clutter a bunch.
Jeremy
Matt Gerard
on Oct 17, 2008 at 6:30:34 pm
Brilliant!!! This is what I was looking for. Should update all my other software and see what else I'm missing...
Matt
