HD to SD downconversion problem
Redžinald Šimek
on Oct 7, 2008 at 12:59:43 pm
Hi
Program that i edited is HD 1080 50i, and my delivery format is PAL Betacam SP.
For HD editing i work on Kona 3 card, but my SD Betacam PVW series deck is connected on the other suite which runs Blackmagic Multibridge extreme card.
When i export HD file and transfer it on the blackmagic suite, SD output looks terrible with blackmagic realtime downconversion.
I try to nest HD into the 10 bit uncompressed SD sequnce but results are same.
I cannot use kona for realtime downconversion because there is no analog audio output from the card.
What i want to try is to use multibridge extreme as standalone converter between aja and analog betacam deck.
Any other suggestions.
thanks
redzinald simek
Bob Zelin
Re: HD to SD downconversion problem
on Oct 8, 2008 at 1:37:51 am
you write -
REPLY -
this is incorrect information. Every AJA Kona 3 should be purchased with the AJA K3 box. This will give you analog audio output, which can go into your Beta VTR, so you can do a HD-SD downconvertion to analog Beta. If you don't have a K3 box, BUY ONE TOMORROW.
Bob Zelin
Redžinald Šimek
on Oct 8, 2008 at 7:23:58 pm
Hi Bob,
you know, i can recognize analog audio output when i see one,
but production for which i work as freelance does not have one, i checked and don't have time, you know, those bloody deadlines, to go to shopping.
I solve my problem, but, anyway, thank you again for your insightful advice.
simek rezinald
