Capture VHS using Kona LHe into FCP
Greg Hammons
on Oct 2, 2008 at 1:51:05 am
Hello- Is it possible to capture video from a consumer VHS deck using the Kona LHe? I only have the breakout cable. I read somewhere that you could connect a BNC to RCA connector to the Y/CVBS in on the breakout cable, but what about the audio capture? If this is possible does the LHe have the ability to enhance the VHS video? If so, how?
Jeremy Garchow
Re: Capture VHS using Kona LHe into FCP
on Oct 2, 2008 at 1:46:33 pm
Connect the Y cable and change the input from component to Composite + y/c in the control panel. As far as audio, you should run through a mixer to boost any levels.
Jeremy
Greg Hammons
on Oct 6, 2008 at 4:06:34 pm
Jeremy- Thanks for the info. Unfortunately I do not have a mixer. Is there another way to get audio into FCP using the LHe card?
