Kona-LHE, posterized garbage on 24P downconvert
Chris Borjis
on Sep 16, 2008 at 12:06:40 am
I have some dvcpro-hd content on a 24p timeline outputting to SD down convert and while its parked on a frame the image looks perfect, but
on playback I see posterized garbage of the image. It does
this on both SDI outs as well as component out.
everything else works just fine (1080i etc...)
Jeremy Garchow
Re: Kona-LHE, posterized garbage on 24P downconvert
on Sep 16, 2008 at 4:19:50 am
Are you sure you selected the proper 720p easy setup before downconverting in the Kona control panel?
It should be the 720p 23.98 DVCpro HD (or whatever codec) VFR setup if you are using v6.
Jeremy
Chris Borjis
on Sep 16, 2008 at 10:57:07 pm
I found that he exported it as uncompressed 10-bit instead of the dvcpro-hd codec and that caused the problem.
thanks Jeremy.
Jeremy Garchow
on Sep 16, 2008 at 11:12:50 pm
Ah, that'll do it! Thanks for posting back.
Jeremy
