1080P/30 10 bit on Kona 3 with Pro Res HQ
Ted Joyce
on Sep 9, 2008 at 6:15:29 pm
I've got 12 hours of HD Cam SR videotape that is 1080p/30 and want to edit it on my brand new Kona3 that I'm just setting up. I'd like to capture it all into ProRes HQ 1080P/30 but I don't see a preset for this in Kona. (I don't have the drive space or speed to edit uncompressed) I've got a 2TB 2 drive raid 0 LeCie F800 drive that should hold it all and is theoretically fast enough. It is a multicamera long form program that I expect to synch up, color correct etc. Any advice?
Jeremy Garchow
Re: 1080P/30 10 bit on Kona 3 with Pro Res HQ
on Sep 9, 2008 at 7:00:29 pm
Use the 1080i ProRes setting, but then you will have to change the field dominance of your clips in the browser after capture from upper to none (and don't forget to do the same to your sequence). This will be a 30psf workflow. If you are capturing true p, then you can download additional easy setups from AJA.com
Jeremy
Ted Joyce
on Sep 9, 2008 at 9:03:46 pm
Great,
Guess I'd need to set the DVCam SR VCR's output PsF rather than P? I assume that is possible. I assume the image quality will be identical using either? The tapes were recorded at Match Frame in LA. I'll be renting a VCR for the in house capture to ProRes.
Thanks Jeremy!
Jeremy Garchow
on Sep 9, 2008 at 9:13:56 pm
You're correct. Which ever you decide to do, you just need to match that in FCP. I'd suggest an sf workflow as not all displays will be able to display true p.
What's DVCam SR ;-D
Jeremy
