preview HD on SD monitor REALTIME
Scott Robert
on Sep 7, 2008 at 7:11:53 am
I thought I was able to do this but I can't figure it out.
I'm editing R3D footage and 1080x720 (from HVX-200) both in 23.98 on FCP. I'm able to view 29.97 SD footage to my JVC SD monitor using the AJA Lhe card. I thought I'm able to preview HD on SD monitor. I get a still frame. But when I change the secondary output to 23.98 and get live playback to SD monitor, the audio goes out of sync. Is my configuration off or do I just need an HD monitor?
Sorry for the dumb question...
Jeremy Garchow
Re: preview HD on SD monitor REALTIME
on Sep 7, 2008 at 5:31:57 pm
Alright. Let's start with what format your footage is.
You say it's R3D, is that raw footage, or have you transcoded it or are you using a red proxy?
1080x720 is not an HD format. Again, what do you really have?
You can downconvert HD matieral to SD with an LHe, but if your footage is beyond 1080, you can't.
Jeremy
Scott Robert
on Sep 7, 2008 at 5:51:33 pm
Thanks for replying.
The RED footage is being transcoded to Apple Pro Res 23.98 2048x1024.
The other footage is 1280x720 23.98.
More footage coming in today will be from a Sony EX. Not sure what HD format yet.
Jeremy Garchow
on Sep 7, 2008 at 6:20:15 pm
Sounds like fun.
The Red footage you will not be able to view in RT as it's 2K and the LHe does not handle 2k. Even if you had a K3, you could not do an rt down conversion as you are already converting the 2K footage to 1080. What you will have to do is place your 2k footage in your 1080 psf timeline and render that footage. You can then do an rt down-convert from 1080 to SD.
Jeremy
Scott Robert
on Sep 7, 2008 at 6:41:11 pm
What about the stuff shot on the HVX-200 1280x720? Should I put that into a 1080 timeline, render it, and then be able to watch it real time?
Jeremy Garchow
on Sep 7, 2008 at 6:46:35 pm
Yep. Make a 1080 23.98 ProRes timeline and drop your footage in there. YOur clips will get scaled up or down and depending on how fast your system is you might be able to play in rt without rendering. You will eventually need to render as FCP will run out of RAM to play your whole timeline in rt.
Make sense?
Now, do you need help with the actual down conversion part of the equation?
Scott Robert
on Sep 7, 2008 at 6:52:12 pm
Downconvert...... uh... sure... I can't drop them into the timeline alone?
Jeremy Garchow
on Sep 7, 2008 at 6:54:26 pm
[Scott Robert] "Downconvert...... uh... sure... I can't drop them into the timeline alone?"
Your Kona can do a real time downconvert from your 1080 timelne to your SD monitor. Isn't that what you really want to do? There's no reason to put your clips in an NTSC timeline.
Scott Robert
on Sep 7, 2008 at 7:19:53 pm
I thought I could do real time downconvert with the Kona. Later today, I will try and create a 1080 timeline, render it, and see if I can get to watch it real time. I'll report back. Thanks.
walter biscardi
on Sep 7, 2008 at 7:35:18 pm
[Scott Robert] "I thought I could do real time downconvert with the Kona. Later today, I will try and create a 1080 timeline, render it, and see if I can get to watch it real time. I'll report back. Thanks."
Yes, all of your footage has to match first of all.
Ensure FCP is in the proper Easy Setup for what you want to edit.
You put all of your HD footage into an HD timeline, if anything has to be rendered, render it.
You take your AJA Control Panel and set your Primary and Secondary Formats for what they should be.
You take one of your outputs and switch it to the SD format.
Now you're doing a realtime downconvert from HD to SD.
FCP is set up for the HD playback, the Kona card is set up for the SD convert.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
View Walter Biscardi's profile on LinkedIn
Scott Robert
on Sep 7, 2008 at 11:17:44 pm
Thanks guys. I can now view HD downconverted to my SD monitor.
Jeremy Garchow
on Sep 7, 2008 at 8:10:02 pm
Here's a write up:
http://forums.creativecow.net/readpost/98/869819
Jeremy Garchow
on Sep 8, 2008 at 3:21:52 am
By the way, I was wrong about the Kona 3, you can in fact do a 2K crop to 1080 and then do an SD down conversion.
Glad you're up and running.
Jeremy
Christopher S. Johnson
on Sep 9, 2008 at 10:54:00 pm
I have a Kona LHe and recently had a Red 2k project that I used a batch process in Compressor to crop for 1080. Was that a waste of time? Is there a better way? I needed my clips to be real native clips in my 1080 timeline with no green RT bars.
-Christopher
Scott Robert
on Sep 10, 2008 at 2:42:05 am
It would be a waste of my time if I did it. Not sure for you. The 4k clips in my 1080 timeline gets the green render bars but without rendering, it plays back perfectly. If I have another video under it, the quality shows reduction. After the log and transfer was completed, I start editing right away with no problem.
