Kona LHe is not giving an image on the HD video monitor
Core van der Hoeven
on Sep 4, 2008 at 4:24:56 pm
I definitely must do something wrong, but I can't get the Kona to work; I just get green lines on my HD video monitor
I work in HDV, analog output in the aja controlpanel is on component SMPT/EBU 1080i25
SDI out gives the same kind of image on the monitor
I'm on the latest drivers (6)
Maybe someone here has an idea what I'm doing wrong you could make me happy
thanks,
Core
Jeremy Garchow
Re: Kona LHe is not giving an image on the HD video monitor
on Sep 4, 2008 at 5:51:01 pm
Have you setup the proper easy setup within FCP?
Did you uninstall and reinstal the drivers?
If you go into the Kona control panel and choose the control tab, set the default video output to Test Pattern > Color bars - 75%, do you see bars?
Jeremy
Core van der Hoeven
on Sep 4, 2008 at 7:03:55 pm
Thanks for your reply,
Yes I do see the test pattern, the color bars
I didn't uninstall and reinstal the drivers, can try that
Core
Jeremy Garchow
on Sep 4, 2008 at 7:09:54 pm
Okay, if you see the test pattern, then open up FCP and choose the proper easy setup by hitting control-q
Jeremy
Core van der Hoeven
on Sep 4, 2008 at 7:16:40 pm
Ok try that first thing in the morning
thanks, Core
Core van der Hoeven
on Sep 4, 2008 at 7:32:15 pm
Although I can't imagine something is wrong there if the external video is set to Kona LHe 1920 1080i 8bit and sequence preset is set to Kona LHe prores 422 1920 1080i
but I'll check this tomorrow
Core
Jeremy Garchow
on Sep 4, 2008 at 7:38:04 pm
[Core van der Hoeven] "Although I can't imagine something is wrong there if the external video is set to Kona LHe 1920 1080i 8bit and sequence preset is set to Kona LHe prores 422 1920 1080i "
Yes it is. ProRes is 10bit, your video output is set to 8 bit. Therein lies the problem.
Jeremy
