Kona 3 install with Huge Ciprico 5116
Dalton Cox
on Aug 27, 2008 at 8:14:19 pm
I am trying to install the above however aja tells me that the Kona 3 is having issues in slots 3 and 4 and that they highly recommend slot 2 with the newer dual quad macs. My problem is that I bought ciprico's new new 5116 raid array which needs 8 lanes to run at spec. That would also be slot 2. Has anyone out there played with this configuration? Any recommendations? I spent the extra money on storage throughput and would hate to throw the performance out of the window.
dalton cox
223
Stuart Ferreyra
Re: Kona 3 install with Huge Ciprico 5116
on Aug 28, 2008 at 7:57:01 pm
I checked on all our systems and they have the Konas in slot 2.
I hope you find a solution :( !
"In Search of a Midnight Kiss" now in theaters!
Stuart Ferreyra
Timecode Multimedia
Colorist / Finisher / Consultant
Off: 310.826.9199
AIM: stuart.colorist
http://www.timecodemultimedia.com
"HD, 2K & RED Post Production for Indies at Affordable Rates"
dalton Cox
on Aug 28, 2008 at 8:03:34 pm
Thanks Stuart. I am setting it up with Kona in slot 2 and ciprico in slot 3. Kevin Bare has been very helpful at Ciprico. He had me adjust a dip switch in the ciprico for use in a 4 lane. He tells me there should not be a loss of performance.
dalton
Bob Zelin
on Aug 28, 2008 at 11:16:46 pm
let me assure you that the Kona 3 works wonderfully in Slot 3, and your storage card in slot 4. If AJA says "you must use slot 2 or it won't work" - then AJA is WRONG. I don't believe that they said this.
Just make sure that everything is in at least a x4 slot. All x8 storage devices are MORE than fast enough for uncompressed HD in a x4 slot. NO MATTER what the storage manufacturer says.
Bob Zelin
Dalton Cox
on Aug 29, 2008 at 12:55:54 am
Thanks Bob! Much appreciated.
The guy I spoke with at aja said that they were having problems with the newest iteration of the mac dual quads. He said something about the 4 lane slots are clocking slower than a typical 4 lane but that a fix was being worked on.
dalton
James Reid
on Aug 29, 2008 at 6:41:53 pm
After much back and forth with AJA support,
they now say that slot 3 is fine with the Kona 3
and Mac Pro early 2008.
Just as Mr Zelin has said.
Dalton Cox
on Aug 29, 2008 at 9:00:17 pm
Thanks James!
Ruslan Akmanov
on Sep 5, 2008 at 2:22:47 pm
My adds to Bob Zelin message.
We used MacPro 2007 with AJA Kona 3 in slot 3 and Apple 4GB 4Channel or ATTO FC-44ES (less stable) in slot 4. Both lines in x4 mode. We got about 570MB/s Write and 620MB/s Read. Up to 2K playback on Kona3.
Now we migrated to last MacPro 3.2 and I put Kona 3 to clot 3 (x4) and ATTO FC-44ES in slot 2 (x16). We got about 810MB/s Write and 710MB/s Read! Kona 3 work fine up to 1080p 25 RGB Dual Link (2K not tested yet). All things is stable and looks fine. Will continue testing for now.
best regards
ruslan_3d
