2K ProRes Files on Aja Kona Lhe, Monitor Playback
Joshua Rosenfield
on Aug 19, 2008 at 5:17:00 am
Hello all,
I've been transcoding RED camera "High" 2k proxies in Compressor to 2k ProRes (145-SQ) QuickTimes for offline of a feature. Perhaps it's not even possible, but is there a way that the AJA Kona LHe card will output the 2k ProRes files in real-time to a 1080i consumer HD tube TV set? I can get 1080i59.94 and 1080psf23.98 (via pulldown) to output to the TV set just fine, but is 2k to 1080 something only the Kona 3 will do? Thanks!
-Joshua
gary adcock
Re: 2K ProRes Files on Aja Kona Lhe, Monitor Playback
on Aug 19, 2008 at 11:51:41 am
[Joshua Rosenfield] "is there a way that the AJA Kona LHe card will output the 2k ProRes files in real-time to a 1080i consumer HD tube TV set?"
Nope
the max video frame size on the LH cards is 1920 as you correctly assume you will have to have the Kona 3 card to handle larger than 2048 or larger frame sizes.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Joshua Rosenfield
on Aug 19, 2008 at 3:46:53 pm
Transcoding to 1080 HD it is then! Thanks!
