Dvcpro 720 50p, fcp only update while stopped playback?
Joel Arvidsson
on Aug 10, 2008 at 5:28:00 pm
Hi, I think this is easy question. I have no problem with monitoring from fcp with dvcpro 720p 25 or 1080p 25p. But now im working with dvcpro 720p 50p and fcp only update the monitor (component output) when i stop playback./Joel
joelarvidsson@gmail.com
Joel Arvidsson
Re: Dvcpro 720 50p, fcp only update while stopped playback?
on Aug 11, 2008 at 1:19:34 pm
Ok, was an easy fix once i checked the settings. Some body could just told switch the settings. I just thought it was wierd since fcp doenst choose the right settings automaticly.
You (read I) just expect it to work since fcp started to feel the clips settings.
cheers
Joel
