Kona 2 breakout box audio
Dan Goulder
on Aug 8, 2008 at 1:52:41 am
Does anyone know if the analogue RCA jacks on the Kona 2 breakout box put out full 24-bit audio, or is it something less?
Thank you.
Bob Zelin
Re: Kona 2 breakout box audio
on Aug 9, 2008 at 9:49:57 pm
Its ANALOG AUDIO ! Not an AES signal that is rated at a bit rate.
Its the same quality as if you were to put an AES to Analog converter on the AES XLR connectors. The sound is excellent (same as a "hi end" AES to analog converter).
Are you the guy that can hear the difference between 44.1k and 48k sampling ?
Bob Zelin
Dan Goulder
on Aug 22, 2008 at 6:39:35 pm
If my question wasn't specific enough... I would like to know if the D/A conversion through the RCA jacks in the Kona 2 breakout box is 24 bit.
No, I'm not the person referred to who claims to be able to hear the difference between 44.1 and 48 Khz (although many do make that claim).
