Help with setup.
Scott Davis
Help with setup.
on Aug 5, 2008 at 5:32:35 pm
This is the gear I have:
MacPro Quad Core
6 G RAM
Cal Digit HD One 6Tb
OS 10.5.2
QT 7.4.5
FCP6.0.3
Kona 3
AJA HD10AVA
Sony HDR- M15 deck
I'm trying to digitize HDV 1080i 29.97 material DV, component out to the HD10AVA, with FW for deck control. The AJA Control Panel is showing me 1080i-29.97 in / Frame Buffer is 1080i-29.97-SDI out is 525-29.97. Easy setup is AJA 525 DV.
I can capture DV clips but it is not downconverting the HD image to 720x480. I do have downconversion set at letterbox.
Any help would be much appreciated. I have scoured the manual and this forum but haven't found anything that is making it click for me.
Thanks in advance
Michael Sacci
Re: Help with setup.
on Aug 6, 2008 at 11:42:18 pm
The Frame Buffer needs to be set on Secondary (525i29.97). The way you have it set the down converting is happening to the video out.
