KONA LH Codec for 720/24P
Mike Maloney
on Jul 28, 2008 at 10:52:02 am
I recently installed the KONA LH. I decided to shoot in on my JVC GY-HD110 some HD-HDV24 frame material and simply find an appropriate codec to capture in FCP. I thought, in the operations manual for the KONA there was a codec for the 720/24, but apparently not so. After trying a plethora of codecs, I couldn't hit one that would work. In order to get the work accomplished, I had to analog out of the JVC and pull back into DVCAM. The footage still looks fantastic, but it's certainly not what I had intended.
What's the correct, or is there, procedure for capturing 720/24 with the KONA LH?
All the best,
Mike Maloney
Mike Maloney
Maloney Marketing Group
maloneymarketinggroup.com
Chris Borjis
Re: KONA LH Codec for 720/24P
on Jul 28, 2008 at 7:21:56 pm
the 720/24P easy setup should do it.
but you MUST capture via firewire that way with the HDV codec.
if you want other codecs (dvcpro-hd, uncompressed, pro-res) then
you need to hookup the component outputs to the kona component inputs and use the 720/59.94 easy setup.
it's really that simple.
Mike Maloney
on Jul 28, 2008 at 11:52:31 pm
Thanks, Chris. This worked...worked quite well. Sometimes the PDF manuals get fuzzy.
Mike Maloney
Chris Borjis
on Jul 29, 2008 at 11:49:20 pm
glad to help :)
