Downconvert on capture from HDV 1080i to DV
Scott Davis
on Jul 11, 2008 at 5:27:05 pm
This is my situation:
-we have 200+hours of footage (mostly 1080i HDV, some Beta SP, some misc.)
-we are doing an offline-online workflow
My workflow at this point is using the Sony HVR-M25U deck-out component-into Kona 3 for realtime downconversion to DV for offline. Capture Beta SP, etc, via Kona 3 as DV. Take into either Avid Symphony via Automatic Duck or online in FCP and recapture at full resolution.
My question is about the HDV deck to Kona 3 into DV conversion. Will this work?
Thanks in advance for any advice.
Scott Davis
Re: Downconvert on capture from HDV 1080i to DV
on Jul 11, 2008 at 6:31:21 pm
Looks like I will need a analog to digital converter also.
Scott Davis
Jeremy Garchow
on Jul 13, 2008 at 5:09:09 pm
Yes, it'll work and you will need an a/d converter. AJA makes them.
You can also come out firewire and have the deck do the downconversion if you want to.
