display Adobe Bridge with Kona 3?
Joe Murray
on Jul 10, 2008 at 2:50:23 pm
Is there a way to do this? I'm sorting through hundreds of hires still photos for an edit, with client behind me at the table, and would like to use the Kona 3 to put the stills on the client monitor.
Appreciate any advice-
Joe Murray
Re: display Adobe Bridge with Kona 3?
on Jul 10, 2008 at 2:56:56 pm
also, tried the Macintosh Desktop display but it requires me to also use the client monitor - bit of neck strain to look up at it so I'm trying to figure a way to keep the Adobe Bridge interface on my monitor AND display it on the client monitor-
Joe Murray
Edit at Joe's
Charlotte, NC
Alan Okey
on Jul 14, 2008 at 3:10:47 pm
Try selecting "mirror displays" in the Display menu. The client monitor and your local monitor will need to be running at the same resolution. What type of client monitor are you using? Hopefully, it's HD-capable.
Joe Murray
on Jul 15, 2008 at 3:54:12 am
Forgot about that setting...it's been a long time since I used a 2-monitor setup. The client monitor is a Panasonic 50" plasma, so it should work.
Joe Murray
Edit at Joe's
Charlotte, NC
