Edit to Tape/Kona/FCP
Robbie Socks
on Jul 2, 2008 at 11:28:13 pm
So i'm trying to EET from an Apple Pro Res Sequence in FCP 6.0.3 (i've also tried this in 8/10 bit without success) to an HD Cam tape (Sony HDW M2000 Deck set to 59.94).
My Kona Card outputs are is set for 1080i @29.97 (which is 59.94 i think).
I have "Printed to Tape" with success, however when i try and use EET the video looks all green and funky.
I have used the Easy set up to set up my output, and I have made sure my kona setting look good, but there are so many options in the kona control panal i don't know if i've selected all the right settings.
Help...this has got to work.
thank you.
Robbie
David Brier
Re: Edit to Tape/Kona/FCP
on Jul 7, 2008 at 2:36:17 pm
You need to check what video is feeding back into your system. I loop the deck signal back to my box, so that the card can lock onto the same signal that I am lying off to (and that jive with my easy set-up). More than likely, that's the culprit, and not your easy set-up. Hope this help comes in time!
David Brier | Post-Op Media
