Using Downconvert from Kona 2 to SD
mark pigott
on Jun 24, 2008 at 5:20:13 pm
Hi! I'd like to take some XDCAM footage off an XDCAM timeline
in FCP and sent it out to a composite SD DVD recorder by using the
Secondary Downconvert (525i 29.97) on a Kona 2.
Problem is; it seems that it will only output in the three output
video mode and not send out the video as composite.
Are there any tricks to this.
gary adcock
Re: Using Downconvert from Kona 2 to SD
on Jun 24, 2008 at 5:57:42 pm
[mark pigott] "Problem is; it seems that it will only output in the three output
video mode and not send out the video as composite. "
Set the AJA control panel to output via composite and use the "green" component channel for the connection to your deck.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
mark pigott
on Jun 24, 2008 at 6:01:53 pm
[gary adcock] "Set the AJA control panel to output via composite and use the "green" component channel for the connection to your deck."
Thanks, after I messaged, I read the manual.
I jumped the gun. All is good.
