capture 16x 9 sdi footage in aja kona 3
vijay bedi
on Jun 19, 2008 at 11:22:38 pm
Hi all!
I am trying to capture un compressed 10 bit sdi 16 x 9 from sony j30 in to aja kno 3 card. But I am not getting stretched 16 x 9 picture. From which I can make normal 16 x9/ 4 x 3 pictures by going in motion and changing the distorted setting.
What I am getting now is 16 x 9 which I don’t want. Can any help me in his pls. kindly email on vijaybedi@rogers.com. thanks vijay
Jeremy Garchow
Re: capture 16x 9 sdi footage in aja kona 3
on Jun 20, 2008 at 1:24:58 am
Vijay, if you are talking 10 UC Sd Sdi you will need to make an anamorphic preset. Simply duplicate the 10 bit settings and check the anamorphic box in both the capture preset and the sequence preset, then make a new easy setup.
File > Audio/Video Settings.
