Kona 3 ProRes HQ - Progressive/Interlaced at 1080 - 29.97?
Bill Paris
on Jun 15, 2008 at 7:57:51 am
Hi Guys,
Can someone help explain something to me? I'm shooting with a Sony F900 at 29.97 PSF (Progressive)
I want to cut using Apple ProRes HQ which only has a 1080i option for 29.97. Do I have to move to something other than ProRes to get progressive capture/editing in 1080/29.97PSF? When I went to the AJA site to get information about this subject, I was surprised to find nothing in the latest PDF manual referencing the Apple ProRes codecs, even though they promote it as a feature on the site and it's part of the latest version of the Kona 3.
The reason its important is for the following: I'm editing a one hour HD special shot with the F900 in 29.97 PSF using the Kona 3 to capture via ProRes HQ 1080i. When I burned a standard def DVD of the first portion of the show for the sponsor, I encountered "buzzing" in the fine detail areas of the picture during playback. I'm concerned that I've interlaced my progressive footage during capture, which is causing the "buzzing" after the DVD encode. I tried a variety of ways to get rid of the problem with out success. Someone later told me I should reduce the detail on the problem scenes, but I would prefer a workflow that doesn't require degrading scenes for a SD DVD.
Any thoughts on this would be greatly appreciated!
Thanks in advance!
Bill Paris
System:
Apple G5
Harpertown 3.o Octacore w/8 Gigs Ram
Kona 3 card
Final Cut Studio 2
HDCAM Deck
gary adcock
Re: Kona 3 ProRes HQ - Progressive/Interlaced at 1080 - 29.97?
on Jun 15, 2008 at 1:23:07 pm
[Bill Paris] "I'm shooting with a Sony F900 at 29.97 PSF (Progressive)
I want to cut using Apple ProRes HQ which only has a 1080i option for 29.97."
it is called interlace in the US and EU due to the limitations set by the EU (same as 25i)
PsF is progressive at capture and in an original data however even though it plays on a display as interlace- as a user you have little choice.
" When I burned a standard def DVD of the first portion of the show for the sponsor, I encountered "buzzing" in the fine detail areas of the picture during playback."
are you monitoring the content on a proper SD device and not just your computer? How are you doing the downconversion? Some content will show these artifacts on downconverts no matter ( herringbone for example) did you convert directly from the ProRes file or something else? did you render out the project to a self-contained movie or did you just output from the timeline directly (never a good idea - no matter what apple says)
"I'm concerned that I've interlaced my progressive footage during capture, which is causing the "buzzing" after the DVD encode"
That makes no sense to me - the SD content HAS TO BE interlaced for playback and
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Bill Paris
on Jun 15, 2008 at 6:03:31 pm
Gary,
Thanks for the clarification regarding the Apple ProRes HQ 1080i PSF codec.
Regarding the DVD encode issue......
To test the DVD, I would take the disc to a consumer player/monitor to make sure it would play properly when my client played it on their system. I also monitored the playback on my Panasonic 17" LCD HD multi-format production monitor.
Before encoding I created a quicktime file using the timeline settings, then down-converted from there.
I wasn't sure the best format to burn from so I tried a variety of SD formats for DVD Studio Pro and also tried to create a format IDVD would like and imported/burned from there. My preference for a quick client burn would be IDVD, since the templates are clean and easier to use than DVD Studio.
After running into the problem, I did some reading on the Cow Encoding Forum and read about de-interlacing footage before burning to DVD, (which is why I thought I might be working with interlaced files created at capture).
The way I ended up burning a viewable DVD for my client was to output the footage to Betacam.... recapturing as DVCPRO 50 and burning from there. Needless to say, the footage looked like &#(&(!
I suppose I could go back to the scenes that gave me the most trouble.... create a matte around the problem area and de-focus the area..... but what a pain!
Should I be looking at changing my encoding program? I understand the Flip For Mac program is very good? Any other ideas? Any guidance would be greatly appreciated. It's frustrating to take great care in the production and post production process to retain quality, only to have it destroyed in the encode/burn!
Thanks for you guidance!
Bill Paris
Jeremy Garchow
on Jun 15, 2008 at 6:51:31 pm
If you want an internally progressive workflow in FCP6 (at least till it plays out psf), what you have to do is capture your footage as 1080i. Then you have to change all the field orders of the clips in the browser to 'None' and then you need to make a 1080p timeline from your 1080i timeline by changing your field dom. to "none" in the sequence as well. That way you footage will be 'interpreted' as progressive and renders from there on out in FCP will be progressive. When you go to make a DVD in Compressor or where ever, make sure to tell the program that your material is progressive and that you want to keep your MPEG2 progressive. It sucks to have to do this, but it's the way it has to be as you can't tell FCP to change the field dominance of incoming clips to 'None' before you capture. So you, dear user, must do it afterwords.
Make sense?
Jeremy
Bill Paris
on Jun 15, 2008 at 11:33:57 pm
Jeremy,
Very interesting! I never would have found this on my own! It's surprising that FCP would not make that a capture option since it adds so much manual manipulation of the clips after the import. Thanks for the information..... once I get back to my edit system, I'll give this a try with my problem clips and see what happens. Thanks again!
Bill Paris
Bill Paris
on Jun 16, 2008 at 12:10:44 am
Jeremy,
One more question...... what's the best way to change the field dominance of the clips in the bin? Via the edit menu... item properties...... format?
Jeremy Garchow
on Jun 16, 2008 at 12:23:36 am
[Bill Paris] "what's the best way to change the field dominance of the clips in the bin?"
If they are in the bin, then simply find the 'Field dominance' column, select all the appropriate clips and right click and choose "None".
If they are already in the timeline, then you have to right click on the clip, choose time properties, find the Field DOminance clip and change it from Upper to None.
Jeremy
Bill Paris
on Jun 16, 2008 at 12:51:08 am
Thanks Jeremy!
giovanni granada
H.264 to ProRes problems
on May 4, 2009 at 10:50:48 pm
Hi Jeremy
Reading your knowledgeable answers I thought you could help me with a technical problem
regarding interlacing problems when converting H.264 to Prores HQ.
Please let me know if I can bother you with this.
Thanks in advance
Giovanni Granada
Jeremy Garchow
Re: H.264 to ProRes problems
on May 5, 2009 at 12:44:39 am
By all means...bother me.
Carsten Orlt
on Jun 16, 2008 at 12:08:31 am
Bill
To clarify first:
When shooting:
Progressive shooting means all video lines are captured at the same instance in time, in your case every 1/30 of a second (ignore the 29.97 for now)
Interlace means that first the odd lines (1/3/5...) and then the even lines (2/4/6...) are captured. This happpens every 1/60 (fields as oppose to frames) of a second effectively creating a full frame every 1/30. So if you shoot interlace and display one frame of your 30 showing all lines there is a difference in time between the alternating lines. Think of a ball traveling from left to right through the picture. When shooting progressive you will have 30 pictures with all lines showing the ball. When you shoot interlaced you will take a 'half-resolution' frame every 1/60 of a second so a full frame will have a slightly different position of the ball between the odd lines and the even lines (1/60 later).
When editing
AJA doesn't give you any 1080p settings for now (I think it'll change soonish) because in the Broadcast world 1080p as a delivery format is virtually not in use (I don't know of any Broadcaster that uses it).
But this doesn't really matter BECAUSE once you shot your footage progressive putting it into a interlace sequence doesn't change it. You have 30 complete frames. At the receiving end will be no difference if I send these frames 30 times per second complete or if I split them into odd and even lines and send those at double the freq of 1/60.
So putting a progressive clip into a interlace seq doesn't make it interlace. To make things clear the techo therefor created the term PSF=progressive segmented frame to be able to tell somebody that the video was shot progressive but is transmitted using the interlace method.
So hard cutting progressive footage in an interlace seq doesn't change the footage. What does change it is anything effecting speed. Because FCP creates new frames by combining fields you could end up taking the odd lines from 1 progressive frame and the even lines from the next progressive frame creating a new frame that is now interlaced (2 instances in time in one frame). You might think this is bad but I actually think its good :-) Because the end user (anybody watching it on a TV) wants a smooth slo mo and they will appreciate you using more time information from your source footage. (This is the reason I wouldn't change the field settings from what FCP uses by default. If you for whatever reason want to avoid any interlace frames in your final seq e.g. for film prints you should use the none setting for both footage and seq as Jeremy said)
So my conclusion to your problem is that the buzzing has nothing to do with interlace but more with the down converting methode you use. Do you use Compressor to convert from your 1080 timeline to your SD Mpeg? And if you do do you switch on the frame control tab in Compressor? I would export the seq from FCP using compressor. Doing this there is no need to export a quicktime first. In Compressor choose the DVD-SD setting from the presets you like (I use the 120min DVD settings for best compatibility with most players) and make sure that the frame controls are switched on. Most likely there are not on which will cause a very bad downscaling quality, which in turn is probably what is causing your buzzing right now.
Sorry that this got a bit long but I think once you understand the whole progressive - interlace thing problems become much more easy to solve.
Hope this will help a little :-) and everybody else please pitch in for corrections or additions!
Carsten
Jeremy Garchow
on Jun 16, 2008 at 12:32:05 am
[Carsten Orlt] "But this doesn't really matter BECAUSE once you shot your footage progressive putting it into a interlace sequence doesn't change it."
Except if you put a clip that's marked as 'Upper Field First' into a progressive timeline, it will look crappy. The field doms of the clips and timeline must match name wise, otherwise FCP interprets them wrong.
[Carsten Orlt] "So putting a progressive clip into a interlace seq doesn't make it interlace."
No it doesn't, but anything you add to it, such as motion or filters will render interlace as that's what the timeline is set up for, so it does matter what your footage and timeline field dom is set for in FCP.
Carsten Orlt
on Jun 16, 2008 at 12:58:10 am
[Jeremy Garchow] "[Carsten Orlt] "But this doesn't really matter BECAUSE once you shot your footage progressive putting it into a interlace sequence doesn't change it."
Except if you put a clip that's marked as 'Upper Field First' into a progressive timeline, it will look crappy. The field doms of the clips and timeline must match name wise, otherwise FCP interprets them wrong. "
It only is a problem if your clip is opposite to your seq. but I have progressive footage as upper field and the seq as upper field or none and both look just fine.
[Jeremy Garchow] "[Carsten Orlt] "So putting a progressive clip into a interlace seq doesn't make it interlace."
Correct but in practical terms it only shows in anything effecting time. if you do CC on a progressive clip in a interlace timeline the result is still progressive or I guess i should say PSF.
Carsten
Jeremy Garchow
on Jun 16, 2008 at 12:16:18 pm
[Carsten Orlt] " if you do CC on a progressive clip in a interlace timeline the result is still progressive or I guess i should say PSF. "
I hear that. I believe that if you want to maintain a progressive workflow, it's best to work progressive and not interlace, especially when you start adding graphics and text that move. But maybe that's just me.
Jeremy
Bill Paris
on Jun 16, 2008 at 1:00:47 am
Carsten,
One more "How To" question....... I went into Compressor to try to switch on Frame Controls, but couldn't find the menu controls....... Any tips? Thanks! And thanks to everyone who contributed to this discussion. This is such a fantastic way to communicate with the experts.... thanks again!
Bill Paris
Carsten Orlt
on Jun 16, 2008 at 1:08:03 am
Bill
once you applied the preset, go into the inspector window, select the 3rd tab (the one with the watch symbol) and first click on the gear symbol on the right. Once you have done that you can switch on the frame controls by choosing it from the top drop-down menu. The one setting that is important for you is the resize setting and the middle selection (linear filter) is a good choice. higher settings will render much longer with little visual improvement. but feel free to experiment :-)
Carsten
Bill Paris
on Jun 16, 2008 at 7:04:31 am
Carsten,
Thanks for the information, I'm going to experiment with your suggestions and attempt my encode again...... Thanks!
Bill Paris
Jeremy Garchow
on Jun 16, 2008 at 12:14:21 pm
Bill, there's another setting you have to check in Compressor to make sure that it sees your movie as progressive.
If you have followed the instructions from before and made everything progressive from footage to timeline, then single click on the movie in compressor to bring up the inspector. In the a/v attributes tab, make sure that your "Native Field Dominance" is set for "Progressive". Then when you go tot he Frame Controls tab as Carsten mentioned, just set it for 'Same as Source'. Sometimes, Compressor will guess wrong at the native field dominance of the clip which will effect processing in Compressor.
Jeremy
gary adcock
on Jun 16, 2008 at 1:13:28 pm
[Carsten Orlt] "AJA doesn't give you any 1080p settings for now "
Totally < UNTRUE > Cartsen. The Kona Cards and IoHD both support 1080 true P for capture and playback- they are available as a separate Download.
"because in the Broadcast world 1080p as a delivery format is virtually not in use (I don't know of any Broadcaster that uses it)."
Again a little off base.- Yes there are spec for 1080 deliverables at 60p in the ATSC specs, you are correct that no one uses them "yet" however.
[Carsten Orlt] "Doing this there is no need to export a quicktime first"
IMHO a self contained QT files always render faster and cleaner than a direct export from the FCP timeline- and it does not lock me out of working then either.
gary adcock
Studio37
Carsten Orlt
on Jun 16, 2008 at 10:00:32 pm
[gary adcock] "Totally < UNTRUE > Cartsen. The Kona Cards and IoHD both support 1080 true P for capture and playback- they are available as a separate Download. "
and where exactly can i find this download?
[gary adcock] "Again a little off base.- Yes there are spec for 1080 deliverables at 60p in the ATSC specs, you are correct that no one uses them "yet" however. "
and why exactly is it off base when you confirm exactly the same I'm saying?
[gary adcock] "IMHO a self contained QT files always render faster and cleaner than a direct export from the FCP timeline- and it does not lock me out of working then either. "
fair point.
gary adcock
on Jun 16, 2008 at 11:20:39 pm
[Carsten Orlt] "and where exactly can i find this download?
resently moved to the archive page ( I will see why)
http://www.aja.com/ajashare/Kona3_v3.4_Additional_Easy_Setups.zip
KONA 3 Additional Easy Setups (ZIP archive) for Final Cut Pro version 5 and KONA Driver software version 3.4 or newer (required) These Easy Setups provide support for 1080p23.98, 1080p24, 1080p25, 1080p29.97, 1080p30, 1080p50, 1080p59.94, and 1080p60—in DVCProHD and 8-bit and 10-bit uncompressed formats. <
They are just easy setups they will still work correctly with the Kona Card.
For the IoHD I made my own- I have been told there are available with a call to support, however you need to make sure you understand the difference between 1080 P and PsF- Most decks do no support 1080 as a True Progressive signal only PsF.
"why exactly is it off base when you confirm exactly the same I'm saying?"
Carsten - 1080 60p is beyond nearly all but the highest end users with an uncompressed bandwidth at nearly 500 megabytes a sec as a DUAL LINK signal and currently only 3-4 camera models that can support the format for acquisition, only SRW1 and 5800SR deck can handle the playback.
It has little if no use as a delivery format since the bandwidth required to handle the material, even as mpeg transport stream, is more than 2x that needed for standard 1080 60i to a satellite now.
gary adcock
Studio37
Bill Paris
on Jun 17, 2008 at 7:57:29 am
Hey Guys,
Wanted to thank you for the "Tech Knowledge". I experimented with the worst clip from my project by following your directions and it made a huge difference! I described the problem as buzzing, but actually it was like the detail level in the camera was set too high and I was getting small image shifts in the fine detailed areas of the picture.... in this case grass. The effect is still there, but it's acceptable for the standard def client DVD. In HD you can see something going on, but it's hardly noticeable. I may experiment with F900 to make sure the detail is not set too high. Thanks again for all the help!
Bill Paris
