XDCAM EX Noise when made into DVCPRO HD
Matt Kerstein
on May 30, 2008 at 7:05:49 pm
I was hoping that there is a way to aviod XDCAM EX Noise when made into DVCPRO HD (via SDI out thru KONA LHe.) Using Pro res seems to look pretty good but Id rather stay in DCPRO HD codec because the buljkof my media is gathered with a HDX900.
Matt
Aloha & Mahalo from Maui
Jeremy Garchow
Re: XDCAM EX Noise when made into DVCPRO HD
on May 30, 2008 at 7:41:17 pm
[Matt Kerstein] "Using Pro res seems to look pretty good but Id rather stay in DCPRO HD codec because the buljkof my media is gathered with a HDX900. "
You should capture your DVCPRo HD to ProRes too.
Jeremy
gary adcock
on May 30, 2008 at 7:53:31 pm
[Matt Kerstein] "I was hoping that there is a way to aviod XDCAM EX Noise when made into DVCPRO HD"
Matt
thats not just theEX's noise pattern, It is inherent in most DVCPROHD footage- capture via HDSDI or comp will help your capture, but this is one of the reasons that ProRes works so well as an intermediate codec- DVCPROHD was designed as an internal camera codec and Panny does an excellent job of being able to process the footage in their hardware - but handling other mfg's footage in DVCPROHD often compounds the native camera noise.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Matt Kerstein
on May 30, 2008 at 9:00:24 pm
Got it..Many Mahalos
Matt
