Urgent: Downconverting from HDV to Digi Beta - Kona 2
Daniel Elder
on May 19, 2008 at 2:06:26 pm
Hi, I am doing tests right now from my downconvert from 1080 60i sequence to my Digi Beta deck. The settings I have in Kona 2 CP are:
Primary setting: 1080 29.97
secondary setting: 525 29.97
Downconvert: anamorphic
Then my SDI out is through the primary. Everything works no problem, but I am losing MAJOR Quality on the downconvert. I am monitoring it through a Panasonic BT-LH1700 as well as a Sony Bravia monitor and both share the same results when on the 480i output. This needs to be mastered today, I'm worried about the quality, can someone guide me through this safely. Thanks a bunch
Daniel Elder
producer
http://www.luminair.com
Jeremy Garchow
Re: Urgent: Downconverting from HDV to Digi Beta - Kona 2
on May 19, 2008 at 4:16:59 pm
FCP should be in your HD easy setup and your SDI output should be set for secondary.
Jeremy
Daniel Elder
on May 19, 2008 at 4:37:30 pm
Ok, I think I did that and it looked much better, I will let you know if anything goes wrong. Thanks
Daniel Elder
producer
