Upconvert using Aja Kona 3 to DVCPro HD
Shaun Lavery
on May 1, 2008 at 12:31:06 am
Ok... this is what I have. DVCPro tapes, a DVCPro 50 deck and Aja Kona 3 card and decklink. I need to take my DVCPro tapes and upconvert them to DVCPro HD. Is there anything else I would need for this upconversion?
walter biscardi
Re: Upconvert using Aja Kona 3 to DVCPro HD
on May 1, 2008 at 12:47:23 am
[Shaun Lavery] "Is there anything else I would need for this upconversion?"
Nope, just make sure you understand how the AJA Control Panel works. This is where you'll be setting up the Upconvert.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
View Walter Biscardi's profile on LinkedIn
Shaun Lavery
on May 1, 2008 at 12:58:26 am
Ok, thanks
what do i need to do in the control panel for the upconvert?
Arnie Schlissel
on May 2, 2008 at 12:35:20 am
You need to go from your DVC Pro 50 deck into the Kona 3 via SDI. You set the Kona 3 to upconvert in the Kona control panel, along with how you want the upconvert to be done- center punch, window box or stretch. Then, in FCP, you set the capture settings to DVCPro HD.
For more info, you can access the help files in the Kona control panel.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
