Question about Kona LHE capturing
Chris Borjis
on Apr 28, 2008 at 7:52:43 pm
I'm looking into getting a Kona LHe for my edit 2 suite (frustrated with black magic) and I have a question on the
way it captures and the aja codecs.
on the black magic multibridge extreme I have, when I run a black magic easy setup, say for example:
Black Magic 10-bit or 8-bit Uncompressed, it actually captures the video as apple uncompressed 10-bit or 8-bit.
the only time I need to render to a black magic codec is if I'm rendering from After Effects or a pc.
So the question is, Do the Kona LH easy setups make it so one can capture apple 10-bit or 8-bit uncompressed video?
Or does it only capture in AJA specific 10-bit or 8-bit uncompressed.
Its vital that fcp projects from either room can be opened in the other without codec issues.
I should add that for the most part, we use ProRes HQ for SD work and DVCPRO-HD for HD work. We occasionally use uncompressed 10-bit for SD.
walter biscardi
Re: Question about Kona LHE capturing
on Apr 28, 2008 at 7:55:08 pm
AJA uses the standard Apple 8 and 10bit Uncompressed codecs.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
View Walter Biscardi's profile on LinkedIn
Chris Borjis
on Apr 28, 2008 at 7:56:37 pm
thanks for the quick response walter.
so I assume the aja specific version of the codec is for outside system rendering. (from a pc or a 3rd party/client for realtime playback of a deliverable)
Jeremy Garchow
on Apr 28, 2008 at 10:35:01 pm
The AJA codecs are MOSTLY used to 10bit RGB Log captures for dual link applications.
Then there's also the cross platform functionality you have alluded to (capture on Mac, edit/composite on PC, finish back on Mac).
If you are staying on the Mac, might as well use the Apple codecs that the defualt easy setups use.
Jeremy
Chris Borjis
on Apr 29, 2008 at 12:27:56 am
Thanks Jeremy.
Jeremy Garchow
on Apr 29, 2008 at 1:42:29 am
Very welcome.
