Upconversion of DV-Material mixed with HDV ...
Matthias Halibrand
on Apr 26, 2008 at 2:34:01 pm
Hi all,
different question regarding what to do best:
I've got a project where HDV and DV is mixed.
The grading will be done in Color.
I'm mediamanaging the timelines at the moment, so the DV-material will be Pal ProRes and the HDV will be HD ProRes for the grading process.
I want to do an HD-CAM-Master and a DigiBeta-Master and would love to use the scaling of the Kona3. But when I scale the PAL-stuff in the HD-timeline the scaling will be done by FCP, if I don't apply scaling it's going to show not fullscreen, of course. So how should I do it?
Second, if I play out to DigiBeta using downconversion, the PAL-stuff will be upconverted by FinalCut and then downconverted by Aja, which is kind of not what I want, since nobody knows, what's the quality loss, there?
If anyone's got suggestions, I'd be very happy if she/he would share them.
MatzeHali
Mitch Sink
Re: Upconversion of DV-Material mixed with HDV ...Teranex Mini?
on Apr 29, 2008 at 11:48:15 pm
Would it be better to capture it as HD (would the Kona do the scaling)?
You could use a Teranex Mini to scale it to HD before it hits the Kona:
http://www.bhphotovideo.com/c/product/481051-REG/Teranex_MINI_UDCS_MINI_UDC...
The above price is wrong. Current MSRP is $2,995. I can get them for under $2,500.
Best Wishes,
Mitch
Matthias Halibrand
on Apr 30, 2008 at 10:25:11 am
Well, yes,
I could recapture about 90min worth 4-second clips from out of about 300 tapes, but I'd rather go the route converting the stuff I already have on my harddrives. :)
So, it seems nobody has any idea.
Well,
I'll try a few ways and report back with the best results ...
Cheers,
MatzeHali
