Fieldproblem (dvcpro HD to digi... crosspost from fcp forum)
Anders Haavie
on Apr 10, 2008 at 6:19:15 pm
Been editing a big hd tvshow and mastered it on a digibeta with aja downscaling on the fly to SD anamorphic. (using the aja app, to downscale to sd) Everything looks ok on my monitor, but the tvstation say that our master has a field problem. (it's shot 720x50p with 25 frames a second). If they look at the tape they can see that sometimes the field 1 and field 2 is the same (correct), and sometimes field 1 and field 2 different, and field 2 is the same as field 1 in the next field. This does not cause the dreaded fielderror on crt screens, but they say that his is not optimal for mpg coding and might degrade quality on air.
Anyone know what this is all about ? blackburst out of sync ? Aja problem ?
(this is posted on the aja forum as well, since this might be an aja problem, not fcp problem)
Anders
Xraid-Xserve-Xsan-Xeverything
Dave Barnard
Re: Fieldproblem (dvcpro HD to digi... crosspost from fcp forum)
on May 21, 2008 at 11:49:42 am
One of my clients has a similar problem with a Kona LHe editing uncompressed SD to DigiBeta.
When editing to tape the output will randomly change, suddenly reversing the field order
This only happens during edit to tape - anyone else seen this type of problem?
Dave Barnard
cinedigital
Dave Barnard
on May 23, 2008 at 1:18:59 pm
Replacing the DVW-2000 digibeta solved the problem - there may be some compatibility issues with later firmware revisions on this machine
