is it possible to run shake with 5.1 NDD drivers?
Joel Arvidsson
on Apr 7, 2008 at 2:43:14 pm
Simple queaston, is it possible to run shake with 5.1 NDD drivers?
I mean they removed the Macintosh Desktop Display feature which i had to use before to get it to work.
joelarvidsson@gmail.com
Joel Arvidsson
Re: is it possible to run shake with 5.1 NDD drivers?
on Apr 7, 2008 at 2:47:31 pm
The same issue is for color aswell, i cant get the aja ouput more than from finalcut.
Jeremy Garchow
on Apr 7, 2008 at 3:02:27 pm
DOn't know about Shake, but Color definitely works. You just have to select the Kona in the user prefs. I would imagine it's the same for Shake.
Jeremy
Arnie Schlissel
on Apr 7, 2008 at 3:45:12 pm
[Jeremy Garchow] "You just have to select the Kona in the user prefs. I would imagine it's the same for Shake."
Shake is a bit different. For Shake, you need to set the Kona to display the desktop. For Color, you need to turn the desktop display off. Not a big deal to change from one to the other, but it can confuse people who don't know or have forgotten.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Joel Arvidsson
on Apr 7, 2008 at 4:07:33 pm
"Shake is a bit different. For Shake, you need to set the Kona to display the desktop."
But isn't that the problem with the new drivers that you cant choose display desktop in aja control panel? when you do its jumps back to whatever you had before.
Thanks for all fast feed back!! It really makes a difference
Arnie Schlissel
on Apr 7, 2008 at 4:24:05 pm
[Joel Arvidsson] "But isn't that the problem with the new drivers that you cant choose display desktop in aja control panel? when you do its jumps back to whatever you had before."
I don't know. I'm still working on a G5 with the other 5.1 drivers.
Arnie
Jeremy Garchow
on Apr 7, 2008 at 4:39:14 pm
[Joel Arvidsson] "But isn't that the problem with the new drivers that you cant choose display desktop in aja control panel? when you do its jumps back to whatever you had before. "
Yes, the NDD drivers disable the Mac desktop feature.
Jeremy
walter biscardi
on Apr 7, 2008 at 3:08:05 pm
[Joel Arvidsson] "The same issue is for color aswell, i cant get the aja ouput more than from finalcut."
Color works perfectly fine here with the NDD drivers and Leopard. Running the Kona 3 with the latest drivers, just be sure to select the proper output format for what you're color grading.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.
STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
View Walter Biscardi's profile on LinkedIn
Joel Arvidsson
on Apr 8, 2008 at 8:13:58 am
Great, Color output now works since i checked in which output it should use. Silly me I was pretty sure it had to have the same "Macintosh Desktop Display" as shake to work.
Have you had any problem with that the colors differs when you checking in "force rgb" vs software (unchecked). I got slightly more saturation when i check in force rgb. How should i tackle it?
And any body here running shake on ajas 5.1 ndd drivers?
