Does Kona Read FCP6 Sequence Timecode?
Russell Lasson
on Apr 1, 2008 at 7:03:03 pm
Will the Kona cards read the timecode from a FCP6 sequence while playing back in FCP? If so, does that allow it to do a timecode window burn on output?
My Kona LH card is on a FCP5 system so I can't test it.
-Russ
Russell Lasson
Kaleidoscope Pictures
Provo, UT
gary adcock
Re: Does Kona Read FCP6 Sequence Timecode?
on Apr 1, 2008 at 8:36:09 pm
[Russell Lasson] "Will the Kona cards read the timecode from a FCP6 sequence while playing back in FCP? If so, does that allow it to do a timecode window burn on output? "
Russell
use the Timecode Settings in the Kona Control Panel....
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Inside look at the IoHD
Russell Lasson
on Apr 1, 2008 at 9:42:30 pm
Thanks Gary.
I gave it a shot starting up from a start-up disk that had FCP6 and sure enough it worked. But when I go back to FCP5.1 on that system, it doesn't work any more:(
But now I know that it works and that's great!
-Russ
Russell Lasson
Provo, UT
