HD-SDI Timecode De-embedder/reader
Marco Solorio
on Mar 22, 2008 at 6:02:27 pm
Does anyone know of an HD-SDI de-embedder/extractor/demuxer/reader that can pull the embedded SMPTE timecode from an HD-SDI signal and spit out LTC timecode? It would be a simple little black box... SDI input (maybe with an SDI loop out) and an LTC output by means of a 1/4" plug or BNC spigot or similarly common TC output connector.
I'm surprised AJA doesn't have a little "gray" box that does this... seems pretty straight forward and they'd be the company to make such a quality device.
Searching the net for days has yielded very little results. The closest I found was this...
http://www.evertz.com/products/8010TM-IRIG
but at a cost of about $3350, I don't think I'll be going that route.
Anyone have any idears?
Marco Solorio | CreativeCow Host | OneRiver Media | Codec Resource Site | Cinesoft | Media Batch
Jeremy Garchow
Re: HD-SDI Timecode De-embedder/reader
on Mar 22, 2008 at 7:20:08 pm
[Marco Solorio] "I'm surprised AJA doesn't have a little "gray" box that does this... seems pretty straight forward and they'd be the company to make such a quality device. "
Oh, but they do:
http://www.aja.com/html_pop/Io_HD_bp.html
Marco Solorio
on Mar 22, 2008 at 7:40:33 pm
LOL, a little overkill for a TC reader, wouldn't you say? Key word *little* gray box! ;-)
Rich Rubasch
on Mar 22, 2008 at 8:58:01 pm
What about the Horita box....this takes the RS422 output of the Kona card or deck and spits out an LTC audio channel. This is how I make timecode matching dubs from HDV to DVCProHD via the Convergent designs M1 box.
I think it is the TG-50. Horita is the timecode conversion/extraction company. Oh, and blackburst generators.
Rich Rubasch
Tilt Media
Marco Solorio
on Mar 22, 2008 at 9:38:58 pm
Thanks, Rich. Yeah I've seen that unit from Horita. Unfortunately it strictly needs to be from an embedded HD-SDI source.
Jeremy Garchow
on Mar 22, 2008 at 9:41:53 pm
[Marco Solorio] "Key word *little* gray box!"
Yeah, it's a bit bigger than little. But for around the same price as the other one you mentioned, it does so much more! :-D
Ramona Howard
on Mar 24, 2008 at 5:07:46 am
Marco,
We do this in RaveHD but it's much bigger than a bread box :) Best of luck in your quest.
Cheers,
Ramona
Jon Lewis
on Mar 24, 2008 at 6:14:26 pm
Try this company and see if it works for you
http://www.adrielec.com/
Jon Lewis
Marco Solorio
on Mar 25, 2008 at 1:09:10 am
Thanks Jon... I actually emailed them over the weekend! They said they might come up with such a device later this year. No luck for now though. =(
I also emailed a couple of other manufacturers, including Markertek to see if they knew of anything... so far no response. :-/
Jacob Varela
on Sep 12, 2008 at 7:11:42 am
Thank you Jon!! this is just what i need.
Alex Wysocki
on Nov 14, 2018 at 7:37:23 am
This is an old thread, but I was looking into this topic and found this:
https://www.markertek.com/product/ese-hd-491-sd/ese-hd-491-sd-hd-sd-sdi-tim...
I think it is an SDI loop that will also read the embedded time code and then convert it to LTC.
